Streetview widget crashes
3321
06-02-2016 12:07 PM
EricVenden
I am using the 2.0.1 version of the StreetView widget for WAB 2.0.  I can get the widget to open up, but it crashes shortly after (10 seconds max).  The widget window suggests looking at the javascript console.  I open that up and the only things that occur around the time I open the widget are:  Chrome Blocker
I am assuming this is some type of built in add blocker for Chrome.
Has anyone else seen this issue?
Thanks for your time
Eric V
Gurnee, IL
Tags (1)
RobertScheitlin__GISP
Eric,
  Normally when I see that the widget works for a few seconds and then quits it is because of a bad Google API Key. You can try and remove the Google API Key altogether from the config_Google Street View.json
