Geopoint-elevation, accuracy, threshold
7986
9
04-26-2016 04:04 PM
BrianKaplan
HI,  can the geopoint in Survey123 capture elevation, the gps accuracy, and can a threshold be set for what a successful geopoint capture cannot go above.
The lat/long presented during selection of a point on the map displays a +/- value.  Can this value be captured.
The xlsform.org describes a body::accuracyThreshold geopointstore_gpsCollect parameter for ODK and that ODK collect captures a point if the +/- is below 5 m.  5m is probably not feasible all locations so it would be nice to set a threshold.
Lastly, elevation would be great to include.
HannahFerrier
Great question!!
We will be adding support for both GPS averaging and GPS accuracy threshold in the next release of Survey123.
This should allow you to determine your location using a range of positions, and to reject all positions that are not within a specified threshold.
Hannah
BrianKaplan
Thank you.
Joseph_Kinyon
This is fantastic news! You keep lining them up and knocking them down. Looking forward to this.
Not sure, is the next release date scheduled?
deleted-user-23WYWUIp9HyE
I'm also curious about how to implement this such that the elevation and coordinates are recorded from the GPS in a form field field for the feature being collected.
Thank you.
Tom
IsmaelChivite
Esri Notable Contributor
Hi Thomas. While GPS Accuracy Thresold was implemented sometime ago, we still do not have a good way for you to extract the X,Y and Z values of a geopoint as attributes in your feature.  Please have a look at this Idea and vote for it if you think it is important: Storing Positional Accuracy of GeoPoints
AndrewHargreaves2
Ismael Chivite‌ thanks for pointing me towards Accuracy Threshold. I know I can easily specify a 1 FOOT accuracy threshold value by stating 0.3048 Meters - however, is it possible to change the message shown to display "FT" instead of "m"?
JamesTedrick
Esri Esteemed Contributor
Hi Andrew,
Currently, the units display only is in meters.  I've added U.S. units display as a possible enhancement.
bearscat7
Hey James,
I'd like my survey 123 elevation data to be in feet not meters.  Is there an expression I can create in the form that converts metric to imperial (US feet), so that it displays in feet?
Sara
ecrdaecrda
Hi Hannah
Did we manage to include the features you have mention above in this current release ?
Hannah
