What is the kernel function ArcGIS is using to compute Kernel Density?
7115
04-19-2016 07:28 AM
MagnusHeitzler
I am searching for the kernel function the ArcGIS tool "Kernel Density" is using. The ArcGIS help mentions the following: "The kernel function is based on the quadratic kernel function described in Silverman (1986, p. 76, equation 4.5)." I have access to the 1998 print of this book where I can find the equation on the very same page. However, when implementing the kernel, I get rather different results from the Gaussian variant, for example. Can therefore anybody tell me the correct kernel function ArcGIS is using? I think it has to be modified to integrate to 1 or something like that.
I remember this question to be answered in the old ESRI forums and I think that I even have the link to it:
http://forums.esri.com/Thread.asp?c=93&f=995&t=98735
Sadly, the link does not work anymore. (Is there a way to access the old forums?)
Thank you very much in advance.
Tags (1)
DanPatterson_Retired
Bill Huber reported on this in an alternate place and on his website
Density
and this link contains references to the book and Bill's comments as well
spatial analyst - What type of kernel density function does ArcMap use? - Geographic Information Sys...
and his discussion here, which most likely drew from the original link
arcmap - Interpretation of ArcGIS Kernel Density legend parameters - Geographic Information Systems ...
sharing to Spatial Analyst​ given the slow spatial stats market
