Attributes of a feature won't sync to server
2633
04-11-2016 11:07 AM
SpencerSmith3
I'm creating a web service that will be passed a list of objects that include the Lat/Long coordinates and some other data such as Speed.  When I use the ArcGISRuntime library to add the features to my map service that is running, the Geometry will appear but none of the attributes ever will.  Here is my code:
                foreach (GPSLocation loc in aLocationsToStore)
                    var theLatLongPoint = new MapPoint(loc.Longitude, loc.Latitude, SpatialReferences.Wgs84);
                    var theProjectedPoint = GeometryEngine.Project(theLatLongPoint, theSpatialReference);
                    var theDateTime = Convert.ToDateTime(loc.DateTime);
                    //Feature gpsFeature = new GeodatabaseFeature(gpsLocFeatureTable.Schema);
                    var gpsFeature = gpsLocFeatureTable.CreateNew();
                    gpsFeature.Geometry = theProjectedPoint;
                    var attributes = gpsFeature.Attributes;
                    attributes["SPEED"] = loc.Speed;
                    await gpsLocFeatureTable.AddAsync(gpsFeature);
                var result = await gpsLocFeatureTable.ApplyEditsAsync(true);
After running this, in the map service I can see the MapPoints in the feature layer, but all of the attribute values of the point are 'null'  Any idea what I'm doing wrong or how I can get the attributes to sync?
EDIT:
I tried sniffing the network data using WireShark and this is what I get for the adds value:
      "geometry":{
         "x":883822.86125507951,
         "y":491566.5768424049,
         "spatialReference":{
            "wkid":102649
      "attributes":{
         "OBJECTID":-10
It seems as though it is overriding all of the attributes that I explicitly define when I call AddAsync.  Any ideas on how to get attributes in the attributes object?
SpencerSmith3
