how to convert feature class to feature set in python
4913
5
03-28-2016 01:22 AM
jayasudha
hi
hi
how to convert featureclass object to featureset object using python and how to convert featureset into featureclass.
please help me with some small code snippet.
DanPatterson_Retired
did you see Featureset in the help files and some of its arcpy methods
FeatureSet—Help | ArcGIS for Desktop
jayasudha
hi
I found in the documentation that ArcGIS server accepts featureset as input and output, but not featureclass. Do i need to convert following script to publish gp service ? If yes how ?
import arcpy
Buffer_distance = arcpy.GetParameterAsText(0)
citybuffer = arcpy.GetParameterAsText(1)
cities = "C:\\project\\test.gdb\\cities"
arcpy.Buffer_analysis(cities, citybuffer, Buffer_distance, "FULL", "ROUND", "NONE", "")
RebeccaStrauch__GISP
There is a sample script at the bottom of the page that Dan linked to. But the command is
feature_set.load(feature_class)
try using your "cities" as the feature_class input and see if that works.
AndrewKeith3
Do you want the GP service to always use the data referenced in the cities variable? Or, do you want to supply a different cities layer each run?
jayasudha
Thanks to all for suggestions.
GP service always use data referenced in cities variable.
