Swipe Plus Widget - option to select 2 layers
3409
03-21-2016 02:27 PM
LianaSmith
I am doing the Application for customer that will allow to compare aerial imagery of many different years. For example, some people want to see how their house looked in 2015 and 2013, other want to compare 2010 and 1998.
If I choose vertical swipe, Widget has an option to Select the layer I want to appear only to the LEFT of the swipe bar. But I need to choose layers for BOTH: Left and Right sides of the bar.
Can the widget be updated somehow???
Thank you very much in advance!!!!!!
RobertScheitlin__GISP
This is a quadruplicate post of this question...
Swipe Plus widget - Option to select 2 layers
Swipe Plus Widget - choose 2 layers for swiping
Several basemaps in a one app
Swipe Plus Widget - how to choose swiping layers
Please do not continuing to post this question about a using this widget in a way that is not supported by it as the developer has moved to a new job and can not continue to support this widget.  What you are wanting to do is not possible through configuration of the widget. Your desired workflow will require custom development.
DanPatterson_Retired
Robert Scheitlin, GISP​ can you lock 3 of the 4 and keep one open, now that you have the redirects done. These are on your side of the Web/GIS divide
