default depending on previous answer
4239
5
03-01-2016 12:12 AM
by Anonymous User
Not applicable
To safe time and to avoid errors I would like to have the default value set to yes if another question before was answered with yes, too. How can I do that?
IsmaelChivite
Esri Notable Contributor
Hi Nicole,
  I thought this could be done through a calculation as in the attached excel file, but this stops working when I change the second question type to a select_one. So for now this does not work. Let us research a bit more.
Ismael
SMW_GIS
Ishmael,
Has this been resolved?  I would like set the default value in a select_one question depending on the choice in another select_one question.
IsmaelChivite
Hi Steve. Unfortunately not. Still sitting in the back-log.
RenatoSalvaleon
Mine is similar but on a select_one, having a default value based on an expression or calculation on survey load or when I open a form. If I hard code a choice name in Default it works. If I use a survey column name in default, select_one breaks. If I use pulldata on the calculation column, select_one breaks as well. Lastly, I tried the survey name of the field that used the pulldata calculation and the behavior is the same.
JamesTedrick
Esri Esteemed Contributor
Hi Renato,
The default column isn't intended to have a formula within it - the now() and today() functions are limited exceptions.
