Picture captions are wrong - Map Journal
4743
8
02-16-2016 09:56 AM
PatrickWalsh1
I created a story map journal and placed multiple pictures in the side panel for each page. For each of these pictures I added a caption and they look fine in the sidebar. When the picture is expanded by the viewer the captions don't always seem to match the picture. The first picture is always right but the second sometimes has the caption from the first repeated or no caption at all. This goes for the third as well. Any suggestions?
AdrianWelsh
MVP Honored Contributor
Sometimes Map Journals get a little screwy with different monitor resolutions. This should not affect your captions but I am wondering if you have tried viewing this map on different browsers or with different resolutions? Or maybe cleared your browser cache?
RupertEssinger
Esri Alum
We'll have a look into that. Could you share your map journal publicly and post the link here, or could you provide a screenshot showing the issue?
Rupert
PatrickWalsh1
AdrianWelsh
Just from my brief glancing around, things look like I would think they should to me. Can you specifically mention where you are seeing problems?
KenBuja
MVP Esteemed Contributor
I'm seeing in on several photos. For example, the second one should be captioned "Home swept away by Meramec River flooding. Photo courtesy of the Post-Dispatch."
PatrickWalsh1
It's only happening to the second or third pictures on a slide in the sidebar.
KateNewell1
I am having the same issue.  Did this ever get resolved?
OwenGeo
Esri Notable Contributor
Please see this GeoNet thread for more info about this issue: Map Journal - image captions
Owen Evans
