Adding extra files to a zip?
3799
01-19-2016 05:46 AM
JemmaWindow
So I got this fantastic script from: Script for Making Individual Zip file for Each Shapefile? but I required some extra files to be added to each of the individual zips, e.g. 2 pdfs: one with metadata and another for terms and conditions.
import arcgisscripting, os, glob, zipfile, shutil
from os import path as p
# Create the Geoprocessor object
gp = arcgisscripting.create()
# arcpy.overwriteOutput = True
gp.overwriteoutput=1
def ZipShapes(path, out_path):
    gp.workspace = path
    shapes = gp.ListFeatureClasses("*")
    # iterate through list of shapefile
    for shape in iter(shapes.next, None):
        name = p.splitext(shape)[0]
        print name
        zip_path = p.join(out_path, name + '.zip')
        zip = zipfile.ZipFile(zip_path, 'w', zipfile.ZIP_DEFLATED)
        os.chdir(path)
        for files in glob.glob('%s.*' %name):
            zip.write(p.join(path,files), files)
        print 'All files written to %s' %zip_path
        # copy pdf files to zip folder
        for f in pdfList:
            shutil.copyfile(os.path.join(os.path.dirname(path),f), os.path.join(path,f))
        zip.close()
if __name__ == '__main__':
    path = r'S:\Species\MARINEFISH'
    outpath = r'S:\Species\MARINEFISH\ZIPS'
    pdfList =["Terms & Conditions of Use.pdf", "METADATA.pdf"]
    ZipShapes(path, outpath)
I keep getting the error:
  File "S:\scripts\Python\Zipping_Shapefiles", line 34, in <module>
  File "S:\scripts\Python\Zipping_Shapefiles", line 25, in ZipShapes
  File "C:\Python27\ArcGIS10.3\lib\shutil.py", line 82, in copyfile
    with open(src, 'rb') as fsrc:
IOError: [Errno 2] No such file or directory: 'S:\\Species\\METADATA.pdf'
Any help would be greatly appreciated!
LukeSturtevant
Did you already look at the obvious issue of 'S:\\Species\\METADATA.pdf' not actually existing? Where is the metadata file located?
Also it looks like you are trying to copy your pdfs to the wrong place? os.path.join(path,f) ​would attempt to copy the pdfs to 'S:\Species\MARINEFISH\ [PDFName]'
RebeccaStrauch__GISP
Assuming this is your own data that you are trying to .zip, and the script is one you received from someone else.....do you even have a "term of use" and "metadata" file created?  It is good to have these items before you distribute data, as a general business practice, but if you don't you can either created the files now, or comment out that line.  but I would suggest at least writing up minimal terms and metadata and saving as PDF in the path shown.
btw...I'm assuming your data is in the same location.
