Context menu
2923
01-11-2016 09:54 PM
PankajTyagi
is there any possibility to create user defined custom context menu in ArcGIS.
Tags (1)
nicogis
IShortcutMenu is an indicator interface that is used only to indicate to the application that the menu should be treated as a context menu. If you are creating a context menu you would implement both IMenuDef and IShortcutMenu
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//0023000000w4000000
nicogis
