Set initial extent not working after deploy?
3251
01-12-2016 10:50 AM
RobertSommers
I'm curious if anyone else is having this problem or has found a way to deal with it:
When I create a new App in Developer I have to choose a web map.  In the web map I have chosen to use the "Web Map's Default Extent" at app initialization.  So, every time the app is initialized it should start at the web map's default extent.
After I deploy the app to our server, however, this default extent preference seems to be "broken".  For example, if I zoom in to the map, then I close the browser window, and then I go back to the map, it initializes at my last view.
Am I missing a setting?  Does anybody else have this issue?  Thanks.
RobertSommers
Thanks, Robert
I just had to comment out the onBeforeUnload function in MapManager.js and it does not save the last extent anymore.
RobertScheitlin__GISP
Derrick,
   See this thread for an explanation and work around:
How to turn off new "auto saved map extent and layer visibility" in Nov 2015 update?
RobertSommers
Thanks, Robert
