Edit Widget - Auto-populate address field reverse geocode
3839
01-11-2016 01:24 PM
LizDaRos
I would love to be able to auto-populate a field in the edit widget with the nearest address. Robert thankfully showed me how to populate a field when creating a new feature and now I would like to perform a reverse geocode in the edit widget and have it auto-populate an editable field. So far I've been able to get the reverse geocode to work in the widget but I can't seem to get the value from the geocode function to populate in the _worksAfterCreate function in the editor Widget.js. What am I doing wrong and how can I get the value from my reverse geocode function to show in another function like the _worksAfterCreate?
     _initGeocoder: function() {
        this.editor.locator = new Locator("my/GeocodeServer");
        this.editor.locator.on("location-to-address-complete", lang.hitch(this, function (evt) {
            var address = evt.address.address;
            var AddrPt = address.Street;
            var AddrPt2 = AddrPt;
    _registerMapEvents: function() {
        this.mapClickEvent = this.map.on("click", lang.hitch(this, function (evt) {
            this.editor.locator.locationToAddress(esri.geometry.Point(evt.mapPoint), 100, null, lang.hitch(this, function () {
     _worksAfterCreate: function(AddrPt2) {
        // add close button to atiInspector
        this._addButtonToInspector();
        // resize editPopup
        this.editPopup.resize(500, 251);
        // update templatePicker for responsive.
        this.editor.templatePicker.update();
        //Add the autopopulate field value from Robert
        this.editor.templatePicker.on("selection-change", lang.hitch(this, function() {
          var selected = this.editor.templatePicker.getSelected();
          if (selected) {
            var featureLayer = selected.featureLayer;
            on.once(featureLayer, "before-apply-edits", lang.hitch(this, function(evt){
            alert(AddrPt2);
              if(evt.adds && evt.adds.length > 0){
                if(evt.adds[0].attributes.hasOwnProperty('ADDRESS')){
                evt.adds[0].attributes.ADDRESS = AddrPt2;
                this.editor.attributeInspector.refresh();
  //End add
        //just for BoxTheme
        setTimeout(lang.hitch(this, this._update), 900);
        // // reset default selectionSymbol that change by Editor dijit.
        // array.forEach(this.editor.settings.layerInfos, function(layerInfo) {
        //   layerInfo.featureLayer.setSelectionSymbol();
        // }, this);
AlistairFox
Hi, you mention above "Robert thankfully showed me how to populate a field when creating a new feature" Can you share this? I need to populate a value into a field through code, not through the user editing it, but need to know where this happens in the code.
BlytheSpendlove
Did you ever figure this out?
