Launchpad theme and panelmanager problem
5461
11-22-2015 07:28 PM
AndrewTerwiel
I've been trying to open a widget from another widget. The code I have works fine for Foldable theme but not for Launchpad theme.
_showWidget: function (widgetName) {
  var wm = WidgetManager.getInstance();
  var pm = PanelManager.getInstance();
  var myWidget = null;
  arrayUtils.some(wm.appConfig.widgetPool.widgets, function (aWidget) {
   if (aWidget.name === widgetName) {
     myWidget = aWidget;
  if (myWidget) {
   var controller = wm.getWidgetsByName("AnchorBarController");
   if (controller.length > 0) {
     var deferred = pm.showPanel(myWidget);
     deferred.then(function (panel) {
       //pm.minimizePanel(panel);
       pm.normalizePanel(panel);
       //pm.maximizePanel(panel);
   else {
line 17 and 19 both work i.e. they perform as expected, but line 18 does nothing. My panel is still hidden.
RobertScheitlin__GISP
Andrew,
  When dealing with a widget in the LaunchPads AnchorBar you have to set the panels position:
         myWidget = aWidget;
      if (myWidget) {
           pm.showPanel(myWidget).then(lang.hitch(this, function(panel){
             panel.setPosition({ top: 120, left: 10, width: 350, height: 480, margin: 10, index: 0 });
         } else {
Andrew,
         myWidget = aWidget;
      if (myWidget) {
         } else {
AndrewTerwiel
Thanks very much, Robert. Works perfectly now.
JamesCrandall
Edit: someone solved with suggestion to use this.map.height * 0.80 to get a percent value.
Is there any way to specify a percentage for the height/width property?
panel.setPosition({ top: 120, left: 10, width: 350, height: 80%, margin: 10, index: 0 });
