i am applying interpolation tool, that time i am defining the output cell size 75, here the processing is completed but the output raster layer is not visible, so what might be the proble, plz help.
4565
11-05-2015 04:50 AM
LitanMohanty
LukeSturtevant
Typically this happens when your spatial reference is a geographic coordinate system the horizontal unit is an arc second or degree. If you set the output coordinate system in the environment settings to a projected coordinate system with a horizontal unit of meter it should work such as this:
LukeSturtevant
DanPatterson_Retired
See the inter-related problem here
