Reconnect to SDE by IWorkspaceFactoryStatus causes errors
3282
10-21-2015 10:57 PM
MarkMindlin
Hi, there,
I am investigating an error (could be one message from two possible messages in the log file) in this method - ConnectWorkspace().
1) error message 1: "Unable to cast SdeWorkspaceFactoryClass to IWorkspaceFactoryStatus
OR
2) error message 2: “The server threw an exception. (Exception from ... (RPC_E_SERVERFAULT))”
It works in a windows service every minute. It seems to be failed after SDE compress. SDE compress executes every night. But the method fails every other week.
Questions:
1)  What line in the code below throws error message 2?
1a) After error message 2 each run of that method creates an additional connection to SDE as a result of that a "Maximum Number of Connections ..." error appears after some time (hours).
2)  How you explain the code in the line:
     IWorkspaceFactoryStatus pWorkspaceFactoryStatus = new ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactoryClass();
   I have no idea why it works and doesn't fail at the first time?
3) Could it be some how linked to memory leaks in the service (I see they exist. I use Red Gate ANTS Memory Profiler)?
4) How to reproduce that errors? I cannot reproduce it in a simple winform using classes from that winservice? Is there any difference how I run the method ConnectWorkspace() and how it runs in the service?
Thanks for any ideas.
       private static bool ConnectWorkspace(ref IWorkspace pWorkspace)
            try
                if (pWorkspace == null)
                    //**This is when the application starts.
                    pWorkspace = null;
                    QAModFun.OpenSDEFromFile(mSDEFlNm, out pWorkspace);
                    return true;
                //**This will happen, after compress the connection is lost, hence the connection needs to be pinged, and
                //**when the status is 'UP' then opening the available connection, and the reconnecting.
                IEnumWorkspaceStatus pEnumWorkspaceStatus = pWorkspaceFactoryStatus.WorkspaceStatus;
                IWorkspaceStatus pWorkspaceStatus = pEnumWorkspaceStatus.Next();
                bool blnConnected = false;
                if (pWorkspaceStatus != null)
                    blnConnected = true;
                    while (pWorkspaceStatus != null && blnConnected == true)
                        if (pWorkspaceStatus.ConnectionStatus != esriWorkspaceConnectionStatus.esriWCSUp)
                if (blnConnected == false)
                    //**Ping the workspace and if 'UP' reconnect.
                    pWorkspaceStatus = pWorkspaceFactoryStatus.PingWorkspaceStatus(pWorkspaceDef);
                    if (pWorkspaceStatus.ConnectionStatus == esriWorkspaceConnectionStatus.esriWCSAvailable)
                        pWorkspaceDef = pWorkspaceFactoryStatus.OpenAvailableWorkspace(pWorkspaceStatus);
                        pWorkspaceDef = null;
                        QAModFun.OpenSDEFromFile(mSDEFlNm, out pWorkspaceDef);
                return true;
            catch (Exception ex)
              WriteToLogFile(ex);
              return false;
MarkMindlin
1a) After error message 2, each run of that method creates an additional connection to SDE as a result of that a "Maximum Number of Connections ..." error appears after some time (hours).
