Add XY data Latitude Category empty upon re using
6324
14
10-14-2015 10:22 AM
EricOstrowski
Whenever I add XY data from a .CSV file the latitude category disappears when I reopen the .CSV file after uploading more data.
Is there a reason why my latitude category disappears when I try to update my coordinates?
The latitude coordinates are present in the .CSV but the option to choose those latitude coordinates is gone.
Tags (1)
DanPatterson_Retired
Darren may be on to something with the potential space in the field name before the Lat and Long fields.  As a test you could try several things
  • just export the Lat and Long data to a separate file and see if it imports
  • move the lat and long fields to the beginning of the file and see if it imports
  • fix the field name
  • ensure there are no blank rows of empty values to be on the safe side.
Check the column... the columns won't be an option if it is represented as text...it may look like a number but it may be formatted as text, and/or the column contains text or blanks
NICOLAPEDDIS
Dan is right, the latitude and the longitude must be formated as number, then you can easly import the csv file in arccatalog or arcmap to trasform the point text in a point feature, and add the z value if is present as formatted a number. If lat and long are not present you wont able to rappresent x, y and z data in arcmap
EricOstrowski
I changed both latitude and longitude columns to number format from general format.
After converting the option to select latitude was still missing.
EricOstrowski
I addition the file does not save the changes from general format to number format.
EricOstrowski
In addition to that*
I assume you are creating this file in something like a spreadsheet, hence if the format can't be changed from general to number there is something in the columns (like spaces) or in the cells that prohibits (like saving degrees minutes and seconds in a column)...but this is conjecture until you copy and paste some of the rows in your initial question to show what you are working with.
EricOstrowski
OBJECTIDAddressCityZipStateTrap SeriesLatitudeLongitudePos_7_17Pos_7_23Pos_8_4Pos_8_5Pos_8_7Pos_8_10Pos_8_13Pos_8_19Pos_8_26Pos_8_28Pos_8_31Pos_9_08Pos_9_09Pos_9_10Pos_9_15Pos_9_16Pos_9_17Pos_9_18Pos_9_28Pos_10_1Pos_10_8Pos_10_13Pos_10_21_15Pos_11_5_15
35Santiago Creek & Bike PathOrange92866CAET-0433.77677-117.8512021111111111111111111111
3621510 E Basin Ave, Walnut DrainOrange92866CAET-0433.79456-117.8312251111111111111111111111
376569 S Kentucky Dr, End of LorettaOrange92866CAET-0433.77736-117.8248211111111111111111111111
3822151 Reneer AveOrange92866CAET-0433.79639-117.8761531111111111111111111111
EricOstrowski
Here is an example of the formatting of our rows with false addresses. We found and replaced some of the spacing issues in the columns however the problem of the latitude category disappearing still persists when we attempt to re add the xy data from the file.
DarrenWiens2
Probably not the issue, but your column "Trap Series" has a space in it, which may throw a monkey wrench in the gears.
