Modifying the Combobox
3567
09-29-2015 07:24 AM
MeghnaNatraj
I am working on having a filter feature in the combobox in ArcpPad,i.e based on the text entered by the user in the "Text" field , I want to show only those options that contain that text as a substring.
I have completed performing this action but once a user enters a text, and i update the list, the text entered by the user gets deleted.
So now if i want to set the text field of the combobox back to the data entered by the user, it prevents me from updating the text field.
I get the error "Class does not support automation"
How do i modify the contents of this Text Field?
Let me know if you need more data to debug this issue.
NICOLAPEDDIS
I suggest you to use arcgis/arcmap and build a mobile geodb axf with the domains.
You can easly build a combobox, then the user can use the axf in the field and add also a different text. When you go in the office and open the axf you will find also the new text in the mobile geodb
MeghnaNatraj
Thanks Nicola, I will look into this.
I have a doubt however!
I read 2 forums
1) ArcPad Developer Help - Concepts (I read on this forum that the comboBox.Text only returns a value but it cannot be set.)
2) GeoNet Forum
Comment made by a user known as  "jason.tipton.gis:
"So, long story short, comboBox.value = x or comboBox.text = x probably should be something to avoid.  Therefore, you have to use comboBox.ListIndex to change the selection. It seems you can always say x = comboBox.value or x = comboBox.text, but not the other way.
And yes, I have logged a bug."
From these 2 , I Infer that we cannot set the text field of a combobox in ArcPad but we read its contents. Is that correct?
Is there any way to set the contents somehow?
Also I am not familiar with building a mobile geodb axf , I will look into it and post back on this thread if i have any doubts! Hope you can help me out?
