ShapeFile
4232
08-03-2015 05:29 AM
Bhargav_KumarK
In Qt SDK, if I want to open a  shape file I need to  follow the procedure which is told in sample LocalServer->Shapefile project. But following this process I am not able to access individual features of Shape file and also not able to load multiple shape files.
Bhargav
LucasDanzinger
Esri Frequent Contributor
Hi Bhargav,
We will be adding native support for shapefiles in an upcoming release, so that you can natively read them without using local server. I believe this will give you the granularity you are looking for. Check out the Android API Ref for a sneak peak & more details, as we should eventually have similar support in Qt
ShapefileFeatureTable | ArcGIS Android 10.2.6 API
ShapefileFeature | ArcGIS Android 10.2.6 API
Luke
LucasDanzinger
Hi Bhargav,
Luke
kishorekumar1
Hi Lucas,
               When will be the next upcoming version of ArcGIS Runtime sdk for Qt released.
Regards,
Kishore Kumar
LucasDanzinger
Kishore-
The current plan is to have beta 1 out in December. Please note that this will not yet have shapefile support. Beta 2 will follow a few months later in 2016. Beta 2 will have support for shapefiles. Final release should be a few months after that.
Luke
