No support for this geometry type.
6240
07-31-2015 11:12 AM
marwamohamed
I am trying to insert a feature in an empty feature class that was created as a polygon feature class
but when i watch the feature class object during debugging i found that it has an esriGeometryAny as a shape type.
so i get this error "No support for this geometry type" at this line
ESRI.ArcGIS.Geodatabase.IFeatureCursor insertCursor = destinationFeatureClass.Insert(false);
Here is the code:
protected virtual void MigrateAfterMerge(MigrationFeatureClassSource source)
            Stopwatch stopWatch = new Stopwatch();
            TimeSpan timeSpan;
            String elapsedTime;
            try
                 stopWatch.Start();
                String groupFieldName = GetGrouByFieldName(source);
                if (groupFieldName != "")
                    List<String> distinctValues = GetDistinctGroupFieldValues(source);
                    ESRI.ArcGIS.Geodatabase.IFeatureClass sourceFeatureClass = source.DataSource.GetFeatureWorkSpaceOfDataSource().OpenFeatureClass(source.SourceTableName);
                    ESRI.ArcGIS.Geodatabase.IFeatureClass destinationFeatureClass = Globals.GlobalsInstance.StandardDB.GetFeatureWorkSpaceOfDataSource().OpenFeatureClass(m_tableName);
                    String whereClause = "";
                    if (distinctValues != null)
                        foreach (String distinctValue in distinctValues)
                            if (distinctValue != "")
                                whereClause += groupFieldName + " = '" + distinctValue + "'";
                                ESRI.ArcGIS.Geometry.IPolygon unionedFeatures = Spatial_Operations.SpatialOperations.MergePolygonsWithCondition(sourceFeatureClass, whereClause);
                                ESRI.ArcGIS.Geodatabase.IFeatureBuffer destinationFeatureBuffer = CreateRecordInStandardDBFromMergeSource(destinationFeatureClass, source, unionedFeatures, ProcessValue(distinctValue, source));
                                insertCursor.InsertFeature(destinationFeatureBuffer);
                        // Flush the buffer to the geodatabase.
                        insertCursor.Flush();
                        stopWatch.Stop();
                        timeSpan = stopWatch.Elapsed;
                        elapsedTime = String.Format("{0:00}:{1:00}:{2:00}.{3:00}",
                    timeSpan.Hours, timeSpan.Minutes, timeSpan.Seconds,
                    timeSpan.Milliseconds / 10);
                        Logger.LoggerInstance.LogOperationStatus(m_tableName + " - Migerating data from " + source.SourceName + " to standard DB succeeded", SyncOperationStatus.Succeded, m_tableName, DateTime.Now, elapsedTime);
            catch (Exception ex)
                stopWatch.Stop();
                Logger.LoggerInstance.LogOperationStatus(m_tableName + " -  Migerating data from " + source.SourceName + " to standard DB failed.", SyncOperationStatus.Failed, m_tableName, DateTime.Now, elapsedTime);
                Logger.LoggerInstance.LogError(ex.Message, DateTime.Now, "MigrateAfterMerge", "MigrationFeatureClass", m_tableName);
               throw new Exception(ex.Message);
seria
by Esri Contributor
When adding a feature to your feature class (programmatically), ensure that the geometry type is ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon.
Creating Features
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#/d/00010000049v000000.h...
You can perform a validation of your newly created feature(s) before actually using the featureclass to create an insert cursor:
Validating Features
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#/Validating_features/00...
