Python: Join Table to Shapefile and export it to GDB
13098
05-21-2015 01:35 AM
PV
Hi
I have many tables which I need to join to a Shapefile. Each table has to be joined to the shapefile seperately and then must be exported into a file GDB.
Anyone knows how to do so with python? Is there a way that the code runs automatically through each table in the folder and joins it to the shapefile, exports it as FC in the GDB, gives it the file name of the table, then removes the join and joins the next table to the same shapefile? I work with ArcGIS 10.1
I came across this site ArcGIS Help 10.1 and also ArcGIS Help 10.1  but I have no clue how to get started to be honest..
JakeSkinner
Esri Esteemed Contributor
Hi P V,
Here is an example on how you could do this:
import arcpy
from arcpy import env
env.overwriteOutput = 1
env.workspace = r"C:\temp\tables"
shapefile = r"C:\data\parcels.shp"
#loopo through tables in C:\temp\tables
for table in arcpy.ListTables("*"):
  #Create a new feature layer, this will remove previous join
  arcpy.MakeFeatureLayer_management(shapefile, "parcelLyr")
  #Join table to feature layer
  arcpy.AddJoin_management("parcelLyr", "PIN", table, "PIN")
  #Retrieve table name
  tableName = table.split(".")[0]
  #Export joined layer to new feature clas
  arcpy.FeatureClassToFeatureClass_conversion("parcelLyr", r"C:\data\ParcelData.gdb", tableName)
JakeSkinner
Hi P V,
import arcpy
PV
Thank you a lot! This code worked PERFECTLY!!!
I only added this line to it: env.qualifiedFieldNames = False
