Unzip files from directory tree
11503
6
05-19-2015 02:34 AM
Yaron_YosefCohen
Continusally to Unzip zip files in folders and subfolders with python - i didn't get an answer. i  work with python 2.7.8 and arcmap 10.3
and i don't why this code does not work with python 2.7.8:
  1. import zipfile
  2. import arcpy,os,os.path,sys
  3. from arcpy import env
  4.
  5. pattern = '*.zip'
  6. folder = r"C:\Project\layers"
  7. files_process = []
  8. for root,dirs,files in os.walk(r"C:\Project\layers"😞
  9.     for filenames in files:
  10.         if filenames == pattern:
  11.             files_process.append(os.path.join(root, filenames))
  12.             zip.extract()
Tags (3)
Yaron_YosefCohen
Finally, this work's for me.
import zipfile,fnmatch,os
rootPath = r"C:\Project"
pattern = '*.zip'
for root, dirs, files in os.walk(rootPath):
    for filename in fnmatch.filter(files, pattern):
        print(os.path.join(root, filename))
        zipfile.ZipFile(os.path.join(root, filename)).extractall(os.path.join(root, filename.split(".")[0]))
ToddBlanchette
You don't have an object named 'zip' that you're calling in the last line.  Read the rest of the link/thread that you posted, especially Dan Patterson​'s reply about researching the module and how to properly use it to extract a zip file.  Throw the code he used there into a for loop, and run it against a directory to unzip all archives.
curtvprice
Suggest moving this to Python
DanPatterson_Retired
Timothy Hales​ an example of the limited moderator ability to move "Developer" threads when posted in the general Discussion section Python development won't get selected unless they navigate.  Again the suggestion to move/alter Developer from level one
Yaron_YosefCohen
i moved it now to Python.
Yaron_YosefCohen
pattern = '*.zip'
Yaron_YosefCohen
