Dynamic segmentation + Arcpy
5689
05-05-2015 02:29 PM
ChukwuemekaEzeiruaku
Item IDBegin EndTestDateConstruction
10000119982000
10010520012000
10021419982000
10034519982000
10043520052000
Requirments include:-
- I would like to segment the dataset to eliminate records with older TestDate to Construction date
- Output table should be non overlapping (begin/end)
Should look like below:-
10010320012000
10043520052000
10025719991998
JaiSiva1
Hi Chukwuemeka,
  If these are the attributes of a feature class , the following code might help :
import arcpy
fc = "c:/data/base.gdb/construct"
fields = ('TestDate', 'Construction')
with arcpy.da.UpdateCursor(fc, fields) as cursor:
    for row in cursor:
       if row[0] < row[1]:
          cursor.deleteRow ()
Hope you would find this useful.
Thanks so much for the code, i was able to get that part done.
Is there a way either with python scripts or other solution to segment the following table to get the result below?
Input table (not a feature class)
1000011998
1001052001
1002171999
1003451998
1004352005
Each segmented section (from-to) should have all the item numbers written to a field that is within a certain range. From the input table, the final table should look like the one below:
Output table
Begin EndTestDateItem IDItem ID
01199810001001
13200110011001; 1002
34199910021001; 1002; 1004
45199810031001; 1002; 1003; 1004
57200510041002
Again Thanks.
JaiSiva1
Hi Chukwuemeka,
From the comparing the input table and output table , it is hard for me to find a condition using which the      output table is generated.
If you can explain the condition & logic involved in detail , it will be helpful.
BlakeTerhune
This appears to be a duplicate post. The other thread has more responses.
Dynamic segmentation with respect to a control factor
