how can I control which language the WebApp will be?
18896
17
05-03-2015 12:58 AM
SPNIOrganization
In the Supported languages section it says : "The language used by the app is determined by your browser's language setting."
Is there a way to control this?
I built the App in Hebrew and I want all the users to see it in Hebrew, no matter what their browser's setting is.
Is that possible?
Deshe.
Tags (1)
SPNIOrganization
well,
No one answered my question but I found the answer so I will share it with you:
In order to control the language you need to use the webappbuilder from your one server and add this code inside the file init.js  : (after or instead of the original code. )
    //override language and orientation
dojoConfig.locale = "he";
window._setRTL(dojoConfig.locale);
AsmaaMohamed
in file (init.js) find this line
dojoConfig.locale = navigator.language ? navigator.language : navigator.userLanguage;
and replace with this line :
dojoConfig.locale = "he" example -> dojoConfig.locale = "ar" this is Arabic app
Asmaa Mohamed
SPNIOrganization
well,
TimWitt2
Hey Deshe Organization
I tried adding this line but it won't work for me. The Webappbuilder loader just keeps loading. When I replace the "he" with "en" it works.
Any idea what I could be doing wrong?
Here is my code:
  if(allCookies.esri_auth){
      /*jshint -W061 */
      var userObj = eval('(' + unescape(allCookies.esri_auth)+ ')');
      if(userObj.culture){
        dojoConfig.locale = userObj.culture;
    if (allCookies.arcgisLocale) {
      dojoConfig.locale = allCookies.arcgisLocale.toLowerCase();
    if (allCookies.wab_locale) {
      dojoConfig.locale = allCookies.wab_locale.toLowerCase();
    if(!dojoConfig.locale){
    dojoConfig.locale = dojoConfig.locale.toLowerCase();
  dojoConfig.locale = "de";
    var resources = [
      window.apiUrl + 'dojo/resources/dojo.css',
      window.apiUrl + 'dijit/themes/claro/claro.css',
      window.apiUrl + 'dojox/editor/plugins/resources/css/TextColor.css',
      window.apiUrl + 'dojox/editor/plugins/resources/editorPlugins.css',
      window.apiUrl + 'dojox/editor/plugins/resources/css/PasteFromWord.css',
      window.apiUrl + 'esri/css/esri.css',
      window.path + 'stemapp/jimu.js/css/jimu.css',
      window.path + 'builder/css/builder.css',
      window.path + 'builder/libs/ace/ace.js',
      window.path + 'builder/libs/thenBy.js'
Tim
SPNIOrganization
Hi Tim,
This is my code. I think the difference starts in line 17 in your code.
try to replace lines 17-18-19 with the part in Bold:
      /*jshint -W061 */
    if(window.queryObject.mode){
      if(allCookies.wab_locale){
        dojoConfig.locale = allCookies.wab_locale;
    }else{
      if(allCookies.wab_app_locale){
        dojoConfig.locale = allCookies.wab_app_locale;
    resources = resources.concat([
      window.apiUrl + 'dojox/layout/resources/ResizeHandle.css',
      window.path + 'jimu.js/css/jimu.css'
TimWitt2
Deshe Organization
I tried this and changed it in the inis.js located at client\stemapp and client\builder
but the webappbuilder just keeps loading
Tim
MajdiTurkman1
Tim Witt wrote:
Deshe Organization
Tim
I have the same problem. page keeps loading.
Did you get any solution? Tim Witt
TimWitt2
Majdi Turkman
I was never able to resolve it. Let me know if you should find a solution.
Tim
Luiz_PauloLima
any solution tim ?
ty
MajdiTurkman1
I have followed the same solution but I'm getting the same result. The page keeps loading!
I'm trying to set the language to Arabic.
Any suggestions?
