Giving click priority to identification over the Coordinate widget?
3273
03-16-2015 04:47 AM
PeteCrosier
Hi, I have setup the Coordinate widget to return the coordinates of a user's click (using the British National Grid coordinate system) - the problem is that this seems to override the feature popup. Now the user's click will only return the coordinates and never open a feature's popup window. I can fix this by opening the Edit widget and closing it again - now when I click on a feature I get the popup and when I click somewhere else I get the coordinates for the click - this is the behaviour I'd expect. Is there a way to make this happen from when the web app is first opened?
StanMcShinsky
Pete Crosier
I have found that same issue. I just tested it on the AGOL version and I found that if the web Mercator projection is not the first listed in the Coordinate widget then it disables the identify popup until I switch it back to the web Mercator projection that updates on the fly not with the user click.
Thanks for pointing that out. I believe this should be a bug reported to ESRI.
-Stan
