Add a definition Query with python
6989
5
02-19-2015 12:05 AM
PeterVersteeg
I want to add a difinition query with python so far i have this
import arcpy
mxd = arcpy.mapping.MapDocument(r"Y:\TRUTTA\Trutta_new\TruttaMaps\test.mxd")
for lyr in arcpy.mapping.ListLayers(mxd, "*"):
    if lyr.name == "chimney_p":
        lyr.definitionQuery = """"Trutta_Map" = '19A4'"""
In my pythonWin it seems to work BUT the query in my shape did not get the new query.
anyone know why that is ?
OwainCatton
Hi Peter,
You are missing just the last step, saving the MXD when you have finished editing the layers.
So your code should read.
import arcpy
mxd.save()
Hope that helps,
Owain
DanPatterson_Retired
The query may have work, but it isn't going to show up unless you are running the script against "CURRENT" See example 2 in this link
PeterVersteeg
thank you Dan this gives my samething to read in the train and learn more about the mapping.
gr Peter
OwainCatton
Hi Peter,
import arcpy
mxd.save()
Hope that helps,
Owain
PeterVersteeg
Thank you Owain,
That did the trick. Did not
know about the save part. My fist try was a error because I had the mxd open in
arcmap. In other scripts a had lock errors. Same scripts work even if the mxd
is open. What are the rules for this ? where can I read about it ?
Greetings Peter
OwainCatton
Afternoon Peter,
As Dan mentioned above, the use of CURRENT instead of a file path would mean that the Python script will edit the current ArcMap session, where as if you specify the file path the Python script will open a new session, hence the locks errors your were getting as you had the MXD already open.
You can read more here http://resources.arcgis.com/en/help/main/10.2/index.html#//00s30000000r000000
  • MapDocument Example 1
    If you have a the MXD open in ArcMap and want to run a script on its contents use CURRENT
  • MapDocument Example 2
    If you want to run the script independently you specifiy te full File Path
Owain
