What means: TypeError: 'Row' object does not support indexing ???
18255
11
01-27-2015 11:57 PM
JohannesBierer
rows1 = arcpy.SearchCursor(fc, ["SHAPE@"])
extents = []
for row1 in rows1:
    ext = row1[0].extent
    extents.append(row1[0].extent)
    print(extents)
DanPatterson_Retired
Examine this
import arcpy
input_shp = 'c:/folder/you_file_here.shp'
arr = arcpy.Array()
with arcpy.da.SearchCursor(input_shp,['FID','SHAPE@']) as cur:
  extents = []
  for row in cur:
    ext = row[1].extent
    p0 = ext.lowerLeft; p1 = ext.upperRight
    print('Extent of shape... {}: '.format(row[0]))
    print(' X min/max  {}, {}'.format(ext.XMin,ext.XMax))
    print(' Y min/max  {}, {}'.format(ext.YMin,ext.YMax))
    arr.add(p0)
    arr.add(p1)
mp = arcpy.Multipoint(arr)
print('Extent of all {}'.format(mp.extent))
JohannesBierer
Thank you
JohannesBierer
Thats what I have so far with the help of dan and xander:
The goal is to create an oldschool image catalog as dbf, because we use a software which can't read the new ones.
import arcpy, os, math
from arcpy import env
Fgdb = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster\RasterCatalog.gdb"
arcpy.env.workspace = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster\RasterCatalog.gdb"
# Ausgabepfad = (r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster").strip()
Ausgabepfad = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster"
ext = ".jpg"
arcpy.AddField_management(Ausgabepfad + "\Orthos_Nummern.shp", "IMAGE", "TEXT", 100) # , "", "", "refcode", "NULLABLE", "REQUIRED")
ext = ".jpg"
fc = os.path.join(Ausgabepfad, "Orthos_Nummern.shp")
fld_oid = "OBJECT_ID" # or: arcpy.Describe(fc).OIDFieldName
fld_out = "IMAGE" # should exist in shapefile
fld_xmin = "XMIN"
arcpy.AddField_management(fc, "XMIN", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED")
arcpy.AddField_management(fc, "XMAX", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED")
arcpy.AddField_management(fc, "YMIN", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED")
arcpy.AddField_management(fc, "YMAX", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED")
input_shp = fc
arr = arcpy.Array()
with arcpy.da.UpdateCursor(input_shp,['FID','SHAPE@']) as cur:
  extents = []
  for row in cur:
    ext = row[1].extent
    Xmin = round((ext.XMin), 0)
    print (Xmin)
    print_attributes(row)
    row.setValue(fld_xmin, Xmin)
    print ( ' X min, {}'.format(ext.XMin))
    curs.updateRow(row)
    arr.add(p0)
    arr.add(p1)
rows = arcpy.UpdateCursor(fc)
for row in rows:
    fld_oid1 = int(row.getValue(fld_oid))
    int_fld_oid1 = str(fld_oid1)
    # path = os.path.join(Ausgabepfad, "{0}{1}".format(row.getValue(fld_oid), ext))
    path = os.path.join(Ausgabepfad, int_fld_oid1 + ext)
    print (path)
    path1 = str("" + path + "")
    row.setValue(fld_out, path)
    rows.updateRow(row)
JohannesBierer
Error message:
File "R:\Karto\zGIS\Python\exportrastercatalog.py", line 49, in <module>
AttributeError: 'list' object has no attribute 'setValue'
Your line numbers are off...any way
    curs.updateRow(row)  should be
    cur.updateRow(row)    there is no curs in the script you have shown
print_attributes(row)  this function is define elsewhere?
you seem to be missing old cursors with new cursors, ie using setValue...you should be using updateRow as in the example here ie access the field by offset number for the row you are working with
JohannesBierer
cur.updateRow(row) doesn't work as well ?
# -*- coding: cp1252 -*-
# Export zu rastercatalog.dbf
# Autor Xander Bakker, Dan Patterson - vermurkst JB
ext = ".jpg"
## arcpy.AddField_management(Ausgabepfad + "\Orthos_Nummern.shp", "IMAGE", "TEXT", 100) # , "", "", "refcode", "NULLABLE", "REQUIRED")
ext = ".jpg"
fld_xmin = "XMIN"
def print_attributes(obj):
    for attr in arr.__dict__:
        print attr, getattr(arr, attr)
input_shp = fc
arr = arcpy.Array()
  extents = []
  for row in cur:
    ext = row[1].extent
    print (Xmin)
    cur.updateRow(row)
    arr.add(p0)
    arr.add(p1)
##rows = arcpy.UpdateCursor(fc)
##for row in rows:
##    fld_oid1 = int(row.getValue(fld_oid))
##    int_fld_oid1 = str(fld_oid1)
##    # path = os.path.join(Ausgabepfad, "{0}{1}".format(row.getValue(fld_oid), ext))
##    path = os.path.join(Ausgabepfad, int_fld_oid1 + ext)
##    print (path)
##    path1 = str("" + path + "")
##    row.setValue(fld_out, path)
##    rows.updateRow(row)
Error:
Extent of shape... 0:
X min/max  3510999.9998, 3511999.9998
3511000.0
_arc_object <geoprocessing array object object at 0x02B88368>
  File "R:\Karto\zGIS\Python\exportrastercatalog.py", line 43, in <module>
Thought I wold get some information through def print attributes?
setValue is replaced by updateRow, I can't find reference to setValue in the new data access cursors...I rarely use them but the error says that you are trying to use a setValue method on a list object, suggesting that row is a list ... you need to define the rows to use in this line
which you haven't, and then reference the column by an offset number ie row[0] would be the FID field and row[1] the SHAPE@ field as in the example I sent you.
Maybe someone who uses 'cursors' will weigh in...I have pretty well switched over to numpy arrays should I have the rare need to work with attributes.
JohannesBierer
In numpy what's wrong about that? How to define the field to write in?
And how to write XMIN, XMAX, YMIN, YMAX in one array and then in the right fields?
npa = numpy.array(Xmin)
arcpy.da.NumPyArrayToTable(npa, fc, fld_xmin)
TypeError: narray.fields require
JohannesBierer
Unfortunately don't get it:
dts = {(fld_xmin,fld_xmax),numpy.int}
    print (dts)
    npa = numpy.array(dts)
       arcpy.da.NumPyArrayToTable(npa, fcout)
What is the sense of the error message:
