ArcGIS Pro Layout - Reference Grid
7300
01-08-2015 07:13 AM
StephenKing
Does anyone know whether you can have a reference grid for a map layout in ArcGIS Pro as in ArcMap - to show lines of lat and long or eastings and northings?
Stephen
DavidWatkins
Esri Alum
It is possible to create a grid in ArcMap and convert it to graphics or use Grid and Graticule Layers in ArcMap to create a grid of features and then it will be included in your map when you import it to ArcGIS Pro.
DavidWatkins
Esri Alum
This functionality will not be available in the first release of ArcGIS Pro.
DavidWatkins
Esri Alum
StephenKing
Thanks David, I can see how the graphic option will work - as long as you don't need to change the map extents once it is in Pro. Looking forward to seeing future developments.
