Scaleline values are wrong
3588
12-19-2014 12:54 AM
LaurentSIBILLE
Hello, we have a problem using the scaleline. The usValue in miles is wrong.
The sdk sample has the problem as you can see in the following pictures.
The same road is about 1km in Sdk Sample but the real value is 630m (tested with Google and other maps).
As you can see in our map, we are using the distance Tools to compare with the scaleline.
Value in meters (1000) from the distance tools is corresponding to the value in miles in the scaleline.
Thank you for your answer,
Best regards.
