Adding a layer (existing point shapefile) from tool output
3573
11-28-2014 10:17 AM
by Anonymous User
Not applicable
My question: can someone please suggest a fix to the code below OR suggest a better way to add an existing point shapefile to a map (not to a geodatabase as this tool will be accessed from a web map using ArcGIS API for JS through REST services once it is published to a server)?
I can't seem to add a point shapefile layer to a map from within a tool, though it works fine from the command line. I've read this thread and followed its suggestions, but still nothing... The particular line that is failing is the last one from below:
precipLayer = arcpy.MakeFeatureLayer_management(precipShape,precipShape) # NOTE: precipShape = existing point shapefile
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
arcpy.mapping.AddLayer(df, precipLayer.getOutput(0), "TOP")
The error from running the tool is:
  File "C:\Users\...\getData.py", line 83, in <module>
  File "c:\program files\arcgis\desktop10.2\arcpy\arcpy\utils.py", line 181, in fn_
    return fn(*args, **kw)
  File "c:\program files\arcgis\desktop10.2\arcpy\arcpy\mapping.py", line 49, in AddLayer
    assert isinstance(add_layer, Layer)
AssertionError
Failed to execute (getData).
If I run this from the command line, then it works (adds the layer twice, of course: once from MadeFeatureLayer and once from AddLayer). But if I remove the .getOutput(0) and run it in at the command line, then I basically get the same error as running it as a tool:
Runtime error
  File "<string>", line 1, in <module>
AssertionError
by Anonymous User
Not applicable
Jeff Barrette‌ made the following suggestion through another post‌ and the tool is now working:
Replace:
precipLayer = arcpy.MakeFeatureLayer_management(r"D:\Active\ArcPY\10x\ScrumWorks\Data\Drive_A\basin_utmcopy.shp")
With:
precipLayer =arcpy.mapping.Layer(r"D:\Active\ArcPY\10x\ScrumWorks\Data\Drive_A\basin_utmcopy.shp")
And remove getOutput(0):
#arcpy.mapping.AddLayer(df, precipLayer.getOutput(0), "TOP")   # GOT ERROR: getOutput(0) doesn't exist
arcpy.mapping.AddLayer(df, precipLayer, "TOP")
by Anonymous User
Not applicable
Replace:
With:
