What is label expression for formatting a number to have thousands separator and decimals?
9354
6
11-25-2014 02:30 PM
RickWarner
I can do this in the  table, but would rather have ability in the labeling of the map.
AnthonyGiles
Honored Contributor
RIck,
If you are after python specific code then you can use the str.format(), see examples here:
Python String Format Cookbook | mkaz.com
AnthonyGiles
Honored Contributor
Rick,
Have a look at this article:
Make Numeric Labels More Readable
You could also use the FormatNumber function in vbscript:
http://www.esri.com/news/arcuser/1104/files/vbscript_label.pdf
Regards
Anthony
KevinBell
def makeMoney(n):
    import locale
    locale.setlocale(locale.LC_ALL, '')
    S = locale.currency(float(n), grouping=True)
    return S
RickWarner
Thank you Kevin,
Is there a way to remove the decimals from the currency, but have the thousands separator. I’m dealing with Sales Price of real estate and there usually no decimal place, ie. 100,000 for a home.
Richard
KevinBell
AnthonyGiles
Honored Contributor
RIck,
Luke_Pinner
MVP Regular Contributor
A one liner (modified from code on Stack Overflow😞
"{:,}".format(int(value))
