add layer in silverlight application
4043
10-27-2014 10:36 PM
yousofothman
hello every body
i have these application
http://yousofmakkawy.maps.arcgis.com/home/item.html?id=5e6059a6b5c44939a043545b61401356
I want to let users add shape file or cad file to the map but I don't no how I do these
can any one help
Message was edited by: yousof othman
DominiqueBroux
Esri Frequent Contributor
Out of using your own server, you can use arcgis.com to generate features from the shapefile and then display the generated features as demonstrated by the 'Create Features from Shapefile' sample.
For CAD file I am not aware of such service so you may have to write your own CAD parser.
DominiqueBroux
yousofothman
thank you Mr.. Dominic i use these sample to add shapefile and it work for me but still I need to add cad layer
and I did not found a solution
