Import Configuration Error
3939
10-09-2013 03:45 AM
by Anonymous User
Not applicable
Original User: tpaschke
I tried to mirgrate a GeoEvent Service by exporting -> importing a configuration and got the following error message:
[ATTACH=CONFIG]28167[/ATTACH]
Can anyone help me fixing this problem? The Log File is attached.
Thanks!
Tom
JavierDelgadillo
Tom,
I haven't seen this error before.
Looking at the stack trace, it seems like it's failing to decrypt the password for one of your ArcGIS Server connections.  Can you try opening up the file in an XML or Text editor and comment out the section with the node arcgisServerConnections and then trying to re-import the configuration?
-Javier
PS Would you mind sharing the configuration with us to so that we can try and figure out what's going on?
by Anonymous User
Not applicable
Thanks for the quick reply Javier!
I already tried to comment out/delete the section arcgisServerConnections as well as all sections except the geoEventServices, inputs, outputs and geoEventDefinitions but neither did work.
I will send you a mail with the unmodified configuration.
Thank you!
