Upgrading ArcGIS server from Standard to Advanced,
5369
5
05-03-2013 01:09 PM
JamalNUMAN
Legendary Contributor
For the time being, I have a license for the ArcGIS server STANDARD with image server.
[ATTACH=CONFIG]24020[/ATTACH], [ATTACH=CONFIG]24021[/ATTACH]
I got an evaluation license for the ArcGIS server STANDARD with other 3 extensions: 3D analyst, spatial analyst and Network analyst. I have generated the ecp file and used it as a new license file but sounds that my ArcGIS server is still in the standard level. It is not upgraded!
[ATTACH=CONFIG]24022[/ATTACH]
What is the best practice to upgrade from Standard to the advanced (with evaluation license of permanent)?
Thank you
Best
Jamal
Jamal Numan
BubbaHey
It's really just a license upgrade.  Run software authorization wizard and when prompted enter the new license number. You can verify the upgrade by checking the keycodes file: C:\Program Files (x86)\Esri\License10.1\sysgen\keycodes
If problems, rename the keycodes file and run the wizard again.
by Anonymous User
Not applicable
Original User: [email protected]
Many thanks Bubba for the help,
I managed to browse to the authorization file and then to re-start the machine to let the new upgrade take effect and it works fine
[ATTACH=CONFIG]24078[/ATTACH], [ATTACH=CONFIG]24079[/ATTACH]
Best
Jamal
BubbaHey
Cool! Welcome!
by Anonymous User
Not applicable
Original User: reseburgn
Thanks, renaming the key code file was what i needed to do, too.  Just once i would like an esri product to work like it should with out having to spend 30 minutes futzing with it to get it to behave.
BubbaHey
I agree. Like the software but the licensing both server and desktop can be a pain.
