Popup / Popup container changing size
6806
8
11-05-2012 08:39 AM
by Anonymous User
Not applicable
Original User: jgiesler
Hello Everyone,
I am having a problem with my popup view controller.  When in my popup view controller if I go to edit a features attributes, then rotate my device the popup with all the attributes then changes size and fill the entire screen.  I set up the Popup view controller using UImodalPresentationFormSheet.  I have attached images of what I am trying to do and what is happening.  I am not sure why this is happening, if anyone has any suggestions please feel free to send them.  Any help would be greatly appreciated.
Cheers,
Jeff
NimeshJarecha
Here is code, how to show popup view controller as form sheet in iPad.
    //present popup view controller
    //if ipad show formsheet
    if ([[UIDevice currentDevice] userInterfaceIdiom] == UIUserInterfaceIdiomPad) {
        self.popupsContainerVC.modalPresentationStyle = UIModalPresentationFormSheet;
 self.popupsContainerVC.modalTransitionStyle = UIModalTransitionStyleCoverVertical;
 [self presentModalViewController:self.popupsContainerVC animated:YES];
    else {
Please let me know if you still see the same issue after using this code.
Regards,
Nimesh
by Anonymous User
Not applicable
Nimesh,
Thanks for the quick reply I just tried the code you sent over.  I am still getting the same issue.   I have attached my current code, it looks pretty much the same as your except I am not checking if the device is an iPad as that is all we are developing to.  I am not sure what can be.  Any additional help would be great.
Jeff
if (PopupGraphics.count > 0)    {
        self.popupVC = [[ AGSPopupsContainerViewController alloc] initWithPopups:PopupGraphics usingNavigationControllerStack:NO];
        self.popupVC.delegate = self;
        self.popupVC.style = AGSPopupsContainerPagingStylePageControl;
        self.popupVC.styleColor = [UIColor blackColor];
        self.popupVC.modalTransitionStyle = UIModalTransitionStyleFlipHorizontal;
        self.popupVC.modalPresentationStyle = UIModalPresentationFormSheet;
        [self presentModalViewController:self.popupVC animated:YES];
NimeshJarecha
Do you see the same issue if you use iPad/iOS 5.1 simulator?
Regards,
Nimesh
by Anonymous User
Not applicable
Yes.
Cheers,
Jeff
NimeshJarecha
Are you sure? I see this issue only with device/simulator running iOS 6, not iOS 5.1. Could you please double check?
Regards,
Nimesh
by Anonymous User
Not applicable
Nimesh,
I missed understood your question(read as I didn't read careful enough), my current deployment target is 5.1 not the simulator. I checked and you are right.  The 5.1 simulator is not causing the same problem.
Jeff
NimeshJarecha
Thanks for confirming. It's iOS SDK/apple issue.
Since, your app is targeting iPad, you should show your popups in UIPopoverController rather than a modal view controller.
You should implement popupsContainer:wantsToShowViewController: ofType:fromViewController:atRect: and popupsContainer:wantsToHideViewController: ofType: methods of AGSPopupsContainerDelegate and show each view in UIPopoverController.
Regards,
Nimesh
by Anonymous User
Not applicable
Nimesh,
Does one of the examples use this method?  I am a little unsure how to implement it or where to put it (still kind of new with ios).  I have attached my code for where i build the AGSPopupsViewController and launch the modalviewController.  Any suggestions would be great.
Cheers,
Jeff
-(void) mapView:(AGSMapView *)mapView didClickAtPoint:(CGPoint)screen mapPoint:(AGSPoint *)mappoint graphics:(NSDictionary *)graphics{
    PopupGraphics = [[NSMutableArray alloc] init];
    for (NSString* key in graphics)
        id value = [graphics objectForKey:key];
        for (AGSGraphic *featureGraphic in value)
            AGSPopupInfo *popupinfo = [AGSPopupInfo popupInfoForGraphic:featureGraphic];
            NSArray *CellBustedValues = [featureGraphic.layer.name componentsSeparatedByString:@" - "];
            if (CellBustedValues.count >1)
                popupinfo.title = [CellBustedValues objectAtIndex:1];
            else
                popupinfo.title = featureGraphic.layer.name;
            AGSPopup *popup = [AGSPopup popupWithGraphic:featureGraphic popupInfo:popupinfo];
            [PopupGraphics addObject:popup];
self.popupVC = [[ AGSPopupsContainerViewControlleralloc] initWithPopups:PopupGraphicsusingNavigationControllerStack:NO];
        [selfpresentModalViewController:self.popupVCanimated:YES];
