Problems with SQL base connecting
3816
02-09-2012 10:21 PM
GeorgeFrolov
Hello, I have a geoportal with Tomcat 6.0, SQL Server 2008, Arcgis Server 10.
In one theme in this topic was discussed the same problem with connecting to SQL Server. I try all things, that was suggested there, but the problem was not resolved.
Geoportal.xml is
<!-- Context configuration file for the Geoportal Web App -->
<Context docBase="geoportal" path="/geoportal" debug="0" reloadable="true" crossContext="true">
    <Resource name="jdbc/gpt" auth="Container" type="javax.sql.DataSource"
              driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver"
              url="jdbc:sqlserver://ROSSTAT:1455;databaseName=geoportal"
              username="gptadmin"
              password="11111"
              maxActive="20"
              maxIdle="10"
              maxWait="-1" />
</Context>
My SQL tcp/ip parameters is
[ATTACH=CONFIG]11865[/ATTACH]
[ATTACH=CONFIG]11866[/ATTACH]
Please help me solve this problem.
by Anonymous User
Not applicable
Original User: jhaodo
Have you added the sqljdbc4.jar file to the tomcat lib folder?
Try testing the connection using ArcCatalog via Add OLE DB connection.
CliveReece
Good suggestion on the jdbc driver jar file.  May I also cross-reference you to this link on the Geoportal Server forum:  http://sourceforge.net/projects/geoportal/forums/forum/1096644/topic/5008622
