When to publish data in a web map vs. a web app
10051
09-03-2014 08:44 AM
CaseyRagain
Is there a resource or some type of decision tree out there that helps outline when one should publish spatial data to a web map on ArcGIS Online versus developing and publishing data to a web application (using the Javascript API as an example?) I'm struggling a little bit when I should use one versus the other. Anyone have experience with this? Thanks in advance.
by Anonymous User
Not applicable
Hi Casey,
The Web Apps are still based off of a Web Map. The benefit of the Web Apps is that the offer in some cases a cleaner layout or special functionality. You can choose to publish using the default apps or download and configure them.
Here is a gallery of our Web Application templates:
http://www.arcgis.com/home/gallery.html#c=esri&t=apps&o=modified&f=configurable
Thanks!
Andra
Did you ever find anything for decision process/review of need for use of ESRI web map & app dev platforms? 🙂
