Python to set Layer properties/symbology/display back ground value RGB 0 0 0
5799
08-16-2014 05:46 AM
PhoukhongPhongsa
Hi friends,
Please help me how to set  Layer properties/Symbology/Display back ground value RGB to value 0 0 0 for all 200 raster files in once with python command?
I tried to use arcpy.SetRasterProperties_management but this is not the correct one.
Thank you in advance!
DanPatterson_Retired
There is no one command, it may be able to be scripted...did you find a tool that will perform it once?
PhoukhongPhongsa
So much time spent and found it here. However, space, indent ...etc. enter.... is challenges!
import os, arcpy, arcpy.mapping
from arcpy import env
mxd = arcpy.mapping.MapDocument("Current")
lstas = arcpy.mapping.ListLayers(mxd,"*.img")
    for las in lstas:
    arcpy.ApplySymbologyFromLayer_management (las, r"C_RE.lyr\20101105t045002_01_or_mo.img")
