Calculating polyline azimuth - code error
14258
16
08-05-2014 01:43 AM
CamillaRootes
Hi. I'm trying to run a Python script in the field calculator to output the azimuth values of a series of polylines. However, everytime I try to run the code it throws the following error:
"File "<string>", line 2, in GetAzimuthPolyline
AttributeError: 'str' object has no attribute 'x'
Failed to execute (CalculateField)."
The code block I am using is:
  1. import math
  2. def GetAzimuthPolyline(shape):
  3. radian = math.atan((shape.lastpoint.x - shape.firstpoint.x)/(shape.lastpoint.y - shape.firstpoint.y))
  4. degrees = radian * 180 / math.pi
  5. return degrees
I sourced the code from this thread Calculate angle of each line in a polyline shapefile‌. It seems to be working for the people in the thread but not for me. I'm running Arc 10.1 with the basic license, by the way.
Can anyone see where this is going wrong?
DanPatterson_Retired
Last kick.  Add a double field, precision 16, scale 4
emulate the field calculator expression before heading to the tool in arctoolboxtest1.jpg
A screen grab of what you are using would help since the code block seems incomplete and improperly formatted.  Also, you are running this with the shapefield as input?
CamillaRootes
Here are some screenshots of what I've been doing:
And this is the error that I am getting:
See the attached image, you were missing the bottom part of the dialog I think.  I am using the field calculator which is much quicker
Also ensure that your field is a Double field with the appropriate width and precision.codeblock.jpg
RiyasDeen
hi Camilla,
What i see from your screen shot is you are trying to calculate value for field Shape and you are passing your shape input as Shape field again.
What is the data type of Shape field? is it a number or geometry?
CamillaRootes
By the bottom part, do you mean the "test = test(!shape!)" bit? Should I put this below my code block or in the 'Expression' box?
I had been using a Float field, so have made a Double field called 'Angle' to see if this works better. But Arc keeps changing 'Angle' back to a Float, any idea why it won't let me use a Double field?
CamillaRootes
Hi, yeah I realised that I was doing that. Hence creating the new 'Angle' field because the 'Shape' field was geometry. But when I try running it to fill the 'Angle' field I now get a generic syntax error.
CamillaRootes
Ah ha! It's just worked. This is the set up that worked:
The only problem is that it is giving me a negative output (-61 degrees in the case of the tester polyline that I used). How can I make the code output the azimuth in the familar True North 0-360 degree output?
RiyasDeen
radian = math.atan((shape.lastPoint.X - shape.firstPoint.X)/(shape.lastPoint.Y - shape.firstPoint.Y))
degrees = math.degrees(radian)
if degrees < 0:
  return degrees + 360
else:
  return degrees
