C# ArcObjects Oracle Connection string
9124
5
08-04-2014 09:01 AM
JordanBaumgardner
Arrrg! I'm having a terrible time translating this connection string, would someone mind taking a stab at it?
Working connection in everything else:
//public string connectString = "SERVER=11.111.11.111;DATABASE=ABCDE;PORT=5121;USER=sde;PASSWORD=password;VERSION=SDE.DEFAULT";
Don't work:
            IPropertySet connectionProps = new PropertySet();
            connectionProps.SetProperty("dbclient", "Oracle11g");
            connectionProps.SetProperty("server", "11.111.11.123");      // Also tried: [11.111.11.123:5121 | 11.111.11.123:5121/ABCDE]
            connectionProps.SetProperty("instance", "5121");                // Also tried [11.111.11.123:5121/ABCDE | 11.111.11.123:5121 | "" ]
            connectionProps.SetProperty("database", "ABCDEF");        // Also tried [ "" | "SDE" ]
            connectionProps.SetProperty("version", "sde.DEFAULT");
            connectionProps.SetProperty("user", "SDE");
            connectionProps.SetProperty("password", "password");
            return workspaceFactory.Open(connectionProps, 0);
I've tried every bloody combination I can think of.
I usually get "Entry for SDE instance not found in services file"
or
"Network I/O error"
or
"SDE not running on server"
Thanks in advance!
RiyasDeen
My recommendation would be to establish connection to your DB in arc catalogue, test the connection.
If test succeeds then pick up your .sde file found @
C:\Users\<<user name>>\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog (windows 7)
Below code establishes connection using the sde file and returns a feature class.
public IFeatureClass GetSdeFeatureClass(string featureClassName)
            IFeatureClass featureClass = null;
            IWorkspaceFactory workspaceFactory = null;
            IFeatureWorkspace destinationWorkspace = null;
            try
                workspaceFactory = new SdeWorkspaceFactoryClass();
                destinationWorkspace = (IFeatureWorkspace)workspaceFactory.OpenFromFile(<<Path to your sde file>>, 0);
                featureClass = destinationWorkspace.OpenFeatureClass(featureClassName);
            catch (Exception ex)
                throw ex;
            finally
                DisposeComObjects(workspaceFactory);
                DisposeComObjects(destinationWorkspace);
            return featureClass;
AdamFeidt
This worked for me:  FYI...Direct Oracle Connection.
    private IGxDatabase2 pGXdb2;
                IPropertySet pPropset = default(IPropertySet);
                IWorkspaceName pInWorkspaceName = default(IWorkspaceName);
                string tInProgID = null;
                pPropset = new PropertySet();
                //create a propertyset using specified settings
                var _with3 = pPropset;
                _with3.SetProperty("SERVER", "");
                _with3.SetProperty("INSTANCE", "sde:oracle11g:ABCDEF");
                _with3.SetProperty("DATABASE", "");
                _with3.SetProperty("USER", "sde");
                _with3.SetProperty("PASSWORD", "password");
                _with3.SetProperty("VERSION", "SDE.DEFAULT");
                pGXdb2 = null;
                // Create the source workspace name.
                pInWorkspaceName = new WorkspaceNameClass();
                pInWorkspaceName.ConnectionProperties = pPropset;
                tInProgID = "esriDataSourcesGDB.SdeWorkspaceFactory";
                pInWorkspaceName.WorkspaceFactoryProgID = tInProgID;
                pGXdb2 = new GxDatabaseClass();
                pGXdb2.WorkspaceName = pInWorkspaceName;
                pGXdb2.Connect();
Adam
RiyasDeen
            try
                throw ex;
            finally
SusannSchmidt
I figthed the same war a few months ago and this is working for me:
string sid="orcl_dbname"; // from tnsnames.ora
IPropertySet connectionProps = new PropertySetClass();
connectionProps.SetProperty("SERVER", sid);
connectionProps.SetProperty("SERVERINSTANCE", "sde:oracle11g:/;LOCAL="+sid);
connectionProps.SetProperty("DATABASE", "");
connectionProps.SetProperty("DBCLIENT", "oracle");
connectionProps.SetProperty("db_connection_properties", sid);
connectionProps.SetProperty("AUTHENTICATION_MODE", "DBMS");
connectionProps.SetProperty("USER", user);
connectionProps.SetProperty("PASSWORD", password);
So good luck!
JordanBaumgardner
Thank you all, I tried Riyas' solution first as it looked the easiest, but I think all of your answers would have solved my issue. Thanks again to all.
KennethDinsmore
If you need the same application to connect to Oracle and SQL Server, you can put the property values in your app.config file and read them from the application. The appsettings section would look something like this for an oracle instance with a sid of "orcl":
<add key="SERVER" value="" />
<add key="DBCLIENT" value="oracle" />
<add key="DATABASE" value="" />
<add key="INSTANCE" value="sde:oracle11g:myserver/orcl" />
<!--DBMS or OSA-->
<add key="AUTHENTICATION_MODE" value="DBMS" />
<add key="USER" value="myuser" />
<add key="PASSWORD" value="mypassword" />
<add key="VERSION" value="SDE.DEFAULT" />
While the same appsettings section for SQL Server might look like this:
<add key="SERVER" value="myserver" />
<add key="DBCLIENT" value="SQL Server" />
<add key="DATABASE" value="mysdedatabase" />
<add key="INSTANCE" value="sde:sqlserver:myserver" />
<!--DBMS or OSA-->
<add key="VERSION" value="dbo.DEFAULT" />
