Hiking equation in python returns wrong results
4914
6
07-30-2014 08:32 AM
GrljAles
I've been trying to implement Tobler's hiking equation in script. The equation goes:
W=6e^{\displaystyle-3.5\left\vert\frac{dh}{dx}+0.05\right\vert}
\frac{dh}{dx}=S=\tan\Theta
Where:
W is walking speed,
S  is slope in degrees.
The list of slopes is:
k7=[-1.0312126698879267, 1.1457628381751035, -3.890124404061796, -0.6875278121450912, 0.0, -1.7820676357665195, -1.0532676344873988, 1.7010978323487986]
And my code is:
    for f in k7:
        tob=6*math.expm1(-3.5*abs(f+0.05))
        k8.append(tob)
Which should be right, but the results are:
k8=[-5.80650137556095, -5.908682283616555, -5.999991269395487, -5.355698099597122, -0.963257875384756, -5.986024888143845, -5.8208760494265395, -5.986925387994366]
First, they are negative and they shouldn't be, second, notice that the slopes are very similar and so should be the results but notice the fifth element of the results! When I tried this with math.exp I got something completly different and also totally wrong.
I know that this should be very simple but I cant figure it out.
Have I missed something in the equation or is there some trick that I should know about.
I would be really grateful for your help.
Aleš
Tags (1)
DouglasSands
You shouldn't be plugging in the slopes into the function. The equation says that it takes the tangent of the slope. Also, I would doubt that slope should be in degrees if it is going into a trig function. In any case, python uses radians so you'll need to convert to radians to use the tangent function:
6 * math.exp(-3.5 * abs(math.tan(math.radians(degrees)) + 0.05)))
For a sanity check, put in a values of the 5th value (0) and the 1st value:
def hike(degrees):
  return 6 * math.exp(-3.5 * abs(math.tan(math.radians(degrees)) + 0.05))
hike(0)
5.036742124615245
hike(-1.0312126698879267)
5.3642655450021355
Both of which checks yield results around 5 km/h which is expected given the input of 0 and a near 0  slope.
Hopefully this helps!
Could you tell me - how is it you format code on the new forums?
DouglasSands
def hike(degrees):
hike(0)
5.036742124615245
5.3642655450021355
GrljAles
Hey Douglas,,
Thank you for advice, it solved my problem! I knew there had to be some simple solution but I'm new to this stuff.
About formatting the code:There is option for formatting in different styles when you are posting the question, however I don't see it here in the reply window.
When posting question it is under the quotation mark as in image:
I tried copying from notepad++ via plugin nppExport but it doesn't work.
Thank you again!
Aleš
DouglasSands
I'm happy to help. Thanks for pointing that out! I hadn't been able to figure it out till now.
RhettZufelt
MVP Notable Contributor
You don't see the syntax option in the reply window, just the original post.  In a reply window, you need to click the "Use advanced editor" link in the upper right and then you will get the syntax highlight option.
R_
ElleryChan
The difficulty of finding the code formatter is being discussed in this thread:  https://community.esri.com/message/390783#390783
GrljAles
Hehe, thank you
Aleš
