Appending multiple GeoDatabases into one
8556
07-26-2014 09:18 AM
iankirschner
I have 5 geodatabases with identical data but of different areas. I am trying to append data from all five to one new geodatabase. There are about 50 feature classes in each geodatabase so I am looking for a script to automate the process.
Leandro-Zamudio
Hi Ian.
I have a code snippet that you can use, To use it Replace the <outputGDB> and <InputGDB1><InputGDB2><InputGDBN> values.
WARNING: It's tested with GDB with the exactly same schema in all GDBs.
import arcpy
from arcpy import env
##Destination GDB
GDBD="<output GDB>"
##List of Origin GDB
GDBS=["<inputGDB1>","<inputGDB2>","...","<inputGDBN>"]
##Set Environment
arcpy.env.workspace=GDBD
##Get List of FDS
FDS=arcpy.ListDatasets()
##Get List of Root Feature Classes
ROOTFCS=arcpy.ListFeatureClasses()
##Append elements in Root Feature Classes
for fcr in ROOTFCS:
    appendinput=[]
    for FCI in GDBS:
        appendinput.append(FCI+"/"+fcr)
    ##print appendinput
    arcpy.Append_management(appendinput,GDBD+'/'+fcr,"TEST")
##Append elements of Feature Classes inside Feature Datasets
for FD in FDS:
    for FC in arcpy.ListFeatureClasses("*","",FD):
        appendinput2=[]
        for FCI2 in GDBS:
                appendinput2.append(FCI2+"/"+FC)
        ##print appendinput2
        arcpy.Append_management(appendinput2,GDBD+'/'+FC,"TEST")
SibghatUllah1
Please see the following video and tool Append Multiple Geodatabase - YouTube
MaryamAhmadi
I need the Appending multiple Geodatabases into one tool for my won desktop GIS 10.8.1.
How to download this tool for free?
