Exporting table to Excel with unchecked fields
4244
07-16-2014 02:37 AM
ArminMueller
i have a problem when exporting a table from a featurelayer with TableToExcel if the featurelayer has unchecked fields. It comes the error message RuntimeError: Cannot find field. The same works fine if no unchecked fields are available.
Here is my code snippet:
Dim objFLayer as IFeatureLayer = me.Layer
Dim objGP As IGeoProcessor = New GeoProcessor
Dim strOutFile As String = IO.Path.Combine(ExportFactory.GetProjectPath(ExportPathEnum.ExportPathEmbfiles),
                                           Me.ID & ".xls")
Try
    objGP.OverwriteOutput = True
    objParameters = New VarArray
    ' Populate the variant array with parameter values.
    objParameters.Add(objFLayer)
    objParameters.Add(strOutFile)
    ' Execute the model tool by name.
    Dim objResult As IGeoProcessorResult = objGP.Execute("TableToExcel_conversion", objParameters, Nothing)
Catch ex As Exception
Finally
    System.Runtime.InteropServices.Marshal.ReleaseComObject(objGP)
    objGP = Nothing
End Try
Someone has an idea? Thank you
Armin
ArminMueller
Hi Duncan,
thank you for your solution. In the meantime i has also find a solution.
Insead of using the ilayer object as parameter input i use the ilayer.name now. After this change it works correct and only the checked fields will be used.
Armin
DuncanHornby
MVP Notable Contributor
Armin,
I have been having a go in VBA at resolving your problem. I too can make it come up with an error message if 1 or more fields has been turned off. Unfortunately I have been unable to resolve it but I did come up with a partial fix that stopped it returning an error. So if you had a dataset with some fields turned off the following code allowed it to run but it ignored the turned off fields. The result is a table in Excel as if you had not turned off any fields...
I think this is a bug (hopefully the ESRI developers will pick up on this thread?) or requires some esoteric fix that is not documented anywhere!
So here is my partial fix:
Public Sub test()
    'Get Map
    Dim pMXDoc As IMxDocument
    Set pMXDoc = ThisDocument
    Dim pMap As IMap
    Set pMap = pMXDoc.FocusMap
    ' Get FeatureLayer (has some fields turned off)
    Dim pLayer As ILayer
    Set pLayer = pMap.Layer(0)
    Dim pFL As IGeoFeatureLayer
    Set pFL = pLayer
    ' Create geoProcessor
    Dim pGP As IGeoProcessor2
    Set pGP = New GeoProcessor
    pGP.OverwriteOutput = True
    pGP.AddOutputsToMap = False
    ' Create parameters
    Dim pVA As IVariantArray
    Set pVA = New VarArray
    With pVA
        .Add pFL.DisplayFeatureClass
        .Add "temp"
    End With
    'Make a tableView called "temp"
    Dim pRes As IGeoProcessorResult2
    Set pRes = pGP.Execute("MakeTableView_management", pVA, Nothing)
    If pRes.Status = esriJobFailed Then
        Debug.Print "Failed tableview"
        Exit Sub
    End If
    ' Create parameters
    With pVA
        .RemoveAll
        .Add "temp"
        .Add "c:\scratch\test.xls"
    End With
    ' Execute tool
    Set pRes = pGP.Execute("TableToExcel_conversion", pVA, Nothing)
    If pRes.Status = esriJobSucceeded Then
        Debug.Print "OK!"
    End If
End Sub
ArminMueller
Hi Duncan,
Armin
DuncanHornby
Unbelievable! I spent nearly an hour looking at this problem as I would have typically passed in the IFeaturelayer object as a parameter. So all you had to do is pass in the layer name instead...
I wish ESRI would document these important but subtle differences.
