Bisect Polygon w/ Arcpy
3823
07-02-2014 11:59 AM
NoahHuntington
[ATTACH=CONFIG]35043[/ATTACH]
How might I bisect the attached polygon in a NE/SW direction using arcpy? Looking for a line feature class as output also. Any suggestions?
T__WayneWhitley
Honored Contributor
...first post on GeoNet, thought I'd use this thread (hope you don't mind Noah) to try out the experience on the new forum format.  Since this seems to be a one-off, I'll even try posting some really rough code below that was constructed interactively (IDLE), but 1st I'll explain the so-called solution.  This may not be good, but it's what came to mind - here it is in basically 3 steps:
1- In the Features toolset (Data Management toolbox), use Minimum Bounding Geometry with the RECTANGLE_BY_AREA geometry type (basic licence level)...
(This part is what is actually shown in the code section below, working on the Min Bound Geom result.)
2- With the known 4 corners of the 'bounding polygon' output, extract the midpoints along the major axis...
3- use some geometry methods and some kind of overlay processing to 'split' the orig poly.
I apologize firsthand for what I resorted to doing in the final step 3, kind of lost the handle on what I was doing and cheated a little using an 'advanced' (and probably inefficient for this use case) couple of heavyduty Feature To Polygon and Feature To Line tool executions (since you wanted the 'oval' outline in 2 line 'mirrored' parts, if I understood correctly?)...yeah, I know, failed to do it all with the lower license and I know well there's a workaround in order to complete the task, but frankly it's beer-thirty and I'm thirsty.  If it cripples you at the last step I can help out tomorrow, but it does the trick with just ver 10.0 (easily adapted to more advanced techniques via 10.2.x).  Okay, remember this was only meant for a one-off, no polish whatsoever, and only meant as a demo to help furnish you an idea how to go about this problem.  Of course this could be dramatically shortened, and improved esp where I failed to include the final hack converting the geom without requiring a higher-than-Basic Desktop license...maybe someone else will do that.   Enjoy, Wayne
...so let's see if I can figure out how to paste this rough-hacked solution:
>>> rows = arcpy.SearchCursor("the MinimumBoundingGeometry result on your oval shape")
>>> row = rows.next()
>>> feat = row.Shape
>>> for point in feat.getPart(0):
...     print point.X, point.Y
535920.293977   123231.784748
537048.195264   124114.261001
537569.582345   123447.87093
536441.681058   122565.395005
>>> anArray = feat.getPart(0)
>>> for i in range(4):
...     print anArray.getObject(i)
535920.293976922 123231.784747839 NaN NaN
537048.195264421 124114.261001259 NaN NaN
537569.582345005 123447.870929845 NaN NaN
536441.681057505 122565.395004511 NaN NaN
>>> newArray = arcpy.Array()
>>> # coords of bisect line
>>> pt1X = anArray.getObject(0).X + (anArray.getObject(3).X - anArray.getObject(0).X)/2
>>> print pt1X
536180.987517
>>> pt1Y = anArray.getObject(3).Y + (anArray.getObject(0).Y - anArray.getObject(3).Y)/2
>>> print pt1Y
122898.589876
>>> # now pt2 to form the other line endpoint...
>>> pt2X = anArray.getObject(1).X + (anArray.getObject(2).X - anArray.getObject(1).X)/2
>>> print pt2X
537308.888805
>>> pt2Y = anArray.getObject(2).Y + (anArray.getObject(1).Y - anArray.getObject(2).Y)/2
>>> print pt2Y
123781.065966
>>> # create the points...
>>> pt1 = arcpy.Point(pt1X,pt1Y)
>>> pt2 = arcpy.Point(pt2X,pt2Y)
>>> # add the points to the new array...
>>> newArray.add(pt1);newArray.add(pt2)
>>> # create the line geometry...
>>> bisect = arcpy.Polyline(newArray)
>>> arcpy.env.workspace = r'C:\Users\whitley-wayne\Documents\ArcGIS\Default.gdb'
>>> arcpy.env.overwriteOutput = True
>>> arcpy.CopyFeatures_management(bisect, 'bisectingLine')
<Result 'C:\\Users\\whitley-wayne\\Documents\\ArcGIS\\Default.gdb\\bisectingLine'>
>>> # define in_features, out_feature_class
>>> in_features = ['ovalTendingNEtoSW', 'bisectingLine']
>>> out_feature_class = 'bisectedPoly'
>>> # try the union again with geom copied to line fc:
>>> arcpy.Union_analysis (in_features, out_feature_class)
Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000366: Invalid geometry type
>>> # wrong gp tool with ERROR 000366, try feat to poly...
>>> # FeatureToPolygon_management (in_features, out_feature_class, {cluster_tolerance}, {attributes}, {label_features})
>>> arcpy.FeatureToPolygon_management (in_features, out_feature_class)
<Result 'C:\\Users\\whitley-wayne\\Documents\\ArcGIS\\Default.gdb\\bisectedPoly'>
>>> # didn't work; try increasing the cluster tolerance...
>>> arcpy.FeatureToPolygon_management (in_features, out_feature_class, '1')
>>> # that worked...
>>> arcpy.FeatureToLine_management("bisectedPoly","bisectedPolyToLine")
<Result 'C:\\Users\\whitley-wayne\\Documents\\ArcGIS\\Default.gdb\\bisectedPolyToLine'>
T__WayneWhitley
Honored Contributor
I got more time to look at this problem again - 3 things I really did not like about the last solution I posted are:
- This was first tried as a 10.0 solution, so I didn't have access to the 10.2.x geometry methods, boundary() and cut(cutter).
- I couldn't think of a 'lower license' solution to 'reconstruct' the oval polygon into 2 bisected parts and resorted to using Feature To Polygon.
- Unfortunately the bisecting line geometry constructed didn't work until I 'fiddled' with the cluster tolerance - this introduced some error.
I have another machine with 10.2.1 installed that yields a better solution (lower license) without introducing error.  Just being lazy before, but a simple solution to overcoming the cluster tolerance challenge is to use a little algebra on the bisecting line to extend it enough to effectively use it as a 'cutter'.  This bit of code (within IDLE) then 'corrects' the 'bisect' line geometry:
>>> # recall (from the previous post) the point coordinates derived from the MBG output
>>> print pt1X;pt1Y;pt2X;pt2Y
536180.987517
122898.58987617493
537308.88880471326
123781.06596555188
>>> slope = (pt2Y - pt1Y)/(pt2X - pt1X)
>>> print slope
0.782405427813
>>> # Y2 - Y1 = slope(X2 - X1)
>>> # Then, say, delta X is 1 unit...then Y2 - Y1 = slope.
>>> pt1Xext = pt1X -1.0
>>> pt2Xext = pt2X +1.0
>>> print pt1Xext;pt2Xext
536179.987517
537309.88880471326
>>> # Y2 = slope + Y1
>>> pt1Yext = -slope + pt1Y
>>> print pt1Yext
122897.807471
>>> pt2Yext = pt2Y + slope
>>> print pt2Yext
123781.848371
>>> # now load the 'corrected' coords into point objs
>>> pt1 = arcpy.Point(pt1Xext,pt1Yext)
>>> pt2 = arcpy.Point(pt2Xext,pt2Yext)
>>> # from the array, create the line geom
...here's where it gets interesting - I access the original oval shape to be cut, but unfortunately I run into a spatial reference required on 'bisect' is missing when trying to make the 'cut' (or bisect):
>>> # same 10.0 command (old-style cursor)
>>> rows2 = arcpy.SearchCursor('ovalTendingNEtoSW')
>>> row2 = rows2.next()
>>> feat2 = row2.shape
>>> type(feat2)
<class 'arcpy.arcobjects.geometries.Polygon'>
>>> # now try the 'new' geom methods
>>> feat2bound = feat2.boundary()
>>> # 'bisect' is the 'cutter':
>>> # cut(cutter)
>>> theBisected = feat2bound.cut(bisect)
  File "<pyshell#43>", line 1, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\arcobjects\arcobjects.py", line 825, in cut
    return convertArcObjectToPythonObject(self._arc_object.Cut(*gp_fixargs((other,))))
RuntimeError: All geometries involved in this operation must have the same spatial reference.
So, this was corrected...the bisect was accomplished - without the need for a higher license (and without the tolerance error).
>>> feat2.spatialReference.PCSName
u'NAD_1983_HARN_StatePlane_Florida_East_FIPS_0901_Feet'
>>> bisect.spatialReference.PCSName
u''
>>> feat2.spatialReference.PCSCode
2881
>>> feat2.spatialReference.factoryCode
2881
>>> sr = arcpy.SpatialReference(2881)
>>> sr.PCSName
>>> # build 'bisect' with a spatial reference
>>> bisect = arcpy.Polyline(newArray, sr)
>>> # no fuss now (hopefully)
>>> theBisected = feat2.cut(bisect)
>>> type(theBisected)
<type 'list'>
>>> for eachGeom in theBisected:
  print str(type(eachGeom))
>>> theBisectedLeft = theBisected[0].boundary()
>>> theBisectedRight = theBisected[1].boundary()
>>> # copy the results to gdb
>>> arcpy.Merge_management([theBisectedLeft,theBisectedRight],'bisectedOvalBoundary')
<Result '\\\\MC-GISAPPSERVER\\mapdocs\\temp\\testData.gdb\\bisectedOvalBoundary'>
>>> # not quite yet, but close...
>>> # need the bisection of the orig boundary poly; not the boundaries of the bisected polys
>>> arcpy.Merge_management([theBisected[0],theBisected[1]],'bisectedOvalBoundary2')
<Result '\\\\MC-GISAPPSERVER\\mapdocs\\temp\\testData.gdb\\bisectedOvalBoundary2'>
>>> # ah, beautiful!
NoahHuntington
Hey Wayne.
Thanks for choosing my example for your experiment.  This is a very ingenious solution and a thorough explanation! I will have to spend a little time working thru the details but  I am very grateful for this excellent response.  I like you am still familiarizing myself with Geonet. But I like what I have seen so far...  Thanks a million, I will add to when I have a grasp on this approach. So appreciated. Thank you!!
-Noah
