ArcSDE 10.1 sp1 upgrade geodatabase error: DB_arcsde_setup: Unable to connect
7134
04-08-2014 01:52 AM
amitjena
Hi All,
While trying to upgrade my ArcSDe geodatabase from 10.1 to 10.1 sp1 with Oracle getting below error as recorded in the SDE_Setup log file.
[Tue Apr 08 14:33:21 2014]
ST_Geometry Schema Owner: (SDE) Type Release: 1007
[Tue Apr 08 14:33:21 2014] Instance initialized for ((sde)) . . .
[Tue Apr 08 14:33:21 2014] Error: Underlying DBMS error (-51).
[Tue Apr 08 14:33:21 2014] Error: DB_arcsde_setup: Unable to connect
[Tue Apr 08 14:33:21 2014] ORA-00933: SQL command not properly ended
[Tue Apr 08 14:33:21 2014] ERROR installing/upgrading ArcSDE, Error = -51
User privileges for geodatabases in Oracle are verified from the below webhelp link:
http://resources.arcgis.com/en/help/main/10.1/index.html#//002n0000002v000000
Also I connect to the geodatabase as ArcSDE admin user (SDE), run the following query and attached is the exported file which looks good:
select object_name, object_type, created, last_ddl_time, status from user_objects where object_type in ('OPERATOR','PACKAGE','PACKAGE BODY','INDEXTYPE','FUNCTION','TYPE','TYPE BODY');
referred the below forum link:
http://forums.arcgis.com/threads/18033-ArcGIS-10-Upgrada-Geodatabase-Error
Attached is the exported file for your reference.
Any suggestion is appreciated.
Regards,
Amit
AsrujitSengupta
You could be encountering a known NIM:
http://support.esri.com/en/bugs/nimbus/TklNMDg2NDEw
[ NIM086410 - Upgrading an Enterprise geodatabase using a database connection established with the traditional syntax for direct connections fails with error 'ORA-00933: SQL command not properly ended']
Try creating a new connection to the Oracle geodatabase using only the TNSNAME(oracle netservice_name) and then try the upgrade.
VinceAngelo
Esri Esteemed Contributor
The version of Oracle (exact version, in A.B.C.D.E notation) is far more important
than the list of objects owned by the SDE user.
- V
AsrujitSengupta
DanielMcAlister
You're a star sir. Solution fixes 10.2.2 upgrade issue I am having as well.
thanks
Dan
amitjena
Thanks Ashru,
That did the trick 😮
Regards,
Amit
