Vehicle Routing Problem
5563
01-14-2014 11:37 PM
VincentAwino
Please help me resolve this error. Anytime I run the VRP solver everything seems to be running ok, but it will only do a partial solve with no routes. It throws the error as shown in the graphic below:
[ATTACH=CONFIG]30510[/ATTACH]
KarelKus
Have you found a solution for this problem? I am dealing with exactly the same thing.
Thanks.
MelindaMorang
Does one of the cost attributes on your network dataset have a space or other special character in the name?  I've seen that "specified column does not exist" message in that circumstance.  If your network does have a cost attribute like that, rename it to something with only letters, digits, and underscores, rebuild the network, and try your solve again.
KarelKus
no I don't have a space or a special character in the name of my cost attributes.
KarelKus
Hi, in the end there was an error in the name of my cost attributes. It wasn't in the attribute table but in the Network Dataset Properties, Attributes tab.
Thank You.
KK
