Web Scene loading problem
1763
05-29-2013 04:49 AM
LukeCzar
Good morning,
I have a problem with Web Scene, everything looks ok, no errors, and when I load my Web Scene it gets stuck at initializing...
Lukasz[ATTACH=CONFIG]24764[/ATTACH]
by Anonymous User
Not applicable
Lucasz,
Can you send me your project file so that I can reproduce it on our side? If you can put on dropbox or your preferred large file transfer method, and just private message me the link to download (see top of screen for messaging link).
Thanks!
Chris
MatthiasBuehler1
Hey ..
Got this working already ?
Let me know ..
Matt
LukeCzar
Hi
We are working on the large scale now (entire campus) I will need to change the base map simply to make it even bigger, I will try to upload all the buildings with a floor plans inside each shell and then I will check if it works or not, I will let you know, cause right now we paused the (smaller project)
I will be in touch
Many thanks for support!!
Lukasz
