Workflow: Select DWG-Layers and Create Mapservice
1286
11-05-2012 03:58 AM
GEO_DATAGmbH
is it possible to create a website where I can create new mapservices from an DWG-file?
- Select annotation and polyline
- choose layer file
I can do it manual with ArcMap. But it should work online.
Please have a lock to the attached pdf.
[ATTACH=CONFIG]19007[/ATTACH]
Are there some examples?
AlexeyTereshenkov
I would go for creating a geoprocessing service for any conversions of the CAD-data into Esri geodatabase format and then using Dynamic Workspaces to let users to create map services on-the-fly with the data they need. If you just want to automate the map service creation process - consider using ArcPy module integration with ArcGIS Server, see the sample in here.
