when we download google street view widget to use in web app builder where do we install the files after downloading
6384
24
08-04-2016 12:25 PM
devarsimajumder2
when we download google street view widget to use in web app builder where do we  install the files after downloading.  I am using web app builder and I have to install one last widget which is the google street view. I have downloaded the files and I am wondering where do we put the folder after we have extracted it. does it go in the client folder or in the apps folder inside of server. thanks! Robert Scheitlin, GISP
RickeyFight
Here:
your path\WebAppBuilderForArcGIS\client\stemapp\widgets
devarsimajumder2
Ok
after i have downloaded it and installed it  how do i link this with the google API? I am not using  google api to build anything so how can i link the  online map to the google API project Robert Scheitlin, GISP
RobertScheitlin__GISP
Devarsi,
Have you seen the widgets help doc (item number 2)?
devarsimajumder2
robert
no i havent seen that. Where can I see  the page that you are talking about? Robert Scheitlin, GISP
Devarsi,
On the widget download page there is a link to the widgets help doc, or in the WAB when in the widgets settings page there is a link at the top called "Learn more about this widget"
devarsimajumder2
Hi Robert
I have it installed in the site map folder but when i go to add it existing to webapp builder and i got to the screen to add it  it comes up with a blank space... i have inserted a image as to how it looks. can you please help me with this? thanks robert.
Devarsi,
  What version of WAB are you using and are you using a equal major release of the widget (i.e WAB 2.1 Google Streetview 2.1)?
devarsimajumder2
robert
I am using the most recent version of google street view and when i make a new  application   it works fine and gives me the customization screen. its only on the exisitng   apps that  i am usng the streetivew on that it isnt working im using  version 1.2 to build the exisiting apps. thanks
Devarsi,
Are you using WAB 1.2 when working on the existing apps or did you import them into WAB 2.1?
