Web Appbuilder Widget Container Problem
1990
6
12-25-2018 07:46 AM
NadirHussain
Dear All
Before my web app builder was working fine.from yesterday i am facing one problem.Before when i create custom widget i can see this widget in container.But from yesterday custom widget not visible in container tray.i try my best i uninstalled web app builder and then again install but i am facing same issue.Please help.
Thanks in Advance
NadirHussain
Thanks Robert,
 it works know.
RobertScheitlin__GISP
Nadir,
  Most of the time when I see this, it is because you have an error in your widget you are developing and it causes the widget to not appear in the widget list. Do you see any errors in the browsers console.
NadirHussain
Dear Robert,
   Sorry for late reply.i was busy in some other tasks.i just copy demo sample from samples folder.and place outside of sample folder.i paste it in client--->stemapp--->widgets.i give the folder name listview.i changes the name in client--->stemapp--->widgets-->listview-->settings.i chenged the setting.js with this line
    baseClass: 'jimu-widget-listview-setting'.
i also changed base class in client--->stemapp--->widgets-->listview    widget.js
 base class line  baseClass: 'jimu-widget-listview'.
i also add the listview widget in client--->stemapp---->config.js
"widgets": [{
"label": "listview",
"uri": "widgets/listview/Widget"
After this i create new application in webApp builder.But i cant see listview widget in widget container.
what i am missing i could not understand.please help.
Thanks in advance.
Nadir,
  Are there any errors in the browsers web console?
NadirHussain
Dear Robert,
i have not seen any errors in the browsers web console.
thanks for your reply
Nadir,
   OK for future reference this step is not needed:
"widgets": [{
If you do not see any errors in the console then the issue is that you are probably looking for the widget to be called listview in the widget choose dialog, but it is still going to be called Demo because the nls/strings.js file still has this (line 3):
define({
  root: ({
    _widgetLabel: "Demo",
    _featureAction_ShowVertex: "Show Vertex Count",
    label1: "I am a demo widget.",
    label2: "This is configurable."
NadirHussain
Thanks Robert,
 it works know.
