Web App Builder Developer Edition - Direction Widget Bug when using with Layer List Widget
1431
08-04-2020 02:44 PM
IanPeebles
Hello everyone.  Not sure if this has been reported, but I believe I found a bug associated with the Directions widget for the Web App Builder Developer Edition.  This was not an issue in Version 2.15, but is an issue in Version 2.16 and 2.17.
The Issue:
- If the layer list is added, the Direction widget will not allow for typing in an address for the second routing choice.  The second option will only allow for typing in one digit and nothing else.
If the layer list is removed, the Directions widget will work.
Has anyone else reported this issue.  A staff member from ESRI was also able to verify the issue.  Any known work arounds or a simple way to fix this issue?
Thank you!
by Anonymous User
Not applicable
Was this resolved?  I'm still seeing it in WAB Dev Edition 2.2:pouting_face:
